wuts wrong with my car!? PLEASE HELP
Old 04-02-2009, 04:52 PM
bobc04's Avatar
Default wuts wrong with my car!? PLEASE HELP
I've been having problems with my car lately. seems like wen i am jus going someplace wiht my car i have to really punch the gas to get going. to put in words that my friend said, feels like it slipping... wut could be wrong?
Old 04-02-2009, 05:42 PM
Automatic or manual trans?
Manual...worn clutch.
Automatic...worn out clutch pack, or low fluid level.
And that's assuming it's your trans that's "slipping."
Old 04-02-2009, 07:13 PM
MusicMan's Avatar
The Jazz Man
Could also be a clogged trans filter.
Old 04-02-2009, 07:19 PM
02StanGT's Avatar
Disengage the e-brake.
Old 04-02-2009, 07:22 PM
MusicMan's Avatar
The Jazz Man
Originally Posted by 02stangt
disengage the e-brake.
rofl!
Old 04-03-2009, 02:29 AM
bobc04's Avatar
k.. did that and still having the same problem... back to the drawing board
Old 04-03-2009, 09:05 AM
02StanGT's Avatar
Do the rpms continue to go up, but the speed stays the same or is slower than normal? You never did say if you had an auto or a manual tranny.
Old 04-03-2009, 10:58 AM
evilkal's Avatar
Does the engine hesitate or does it rev like normal? If it hesitates, your cat could be clogged. If it revs like normal, you likely either have a worn out clutch (manual), low fluid, or your torque converter is wearing out (auto).
Some more info on the problem would be nice
Old 04-03-2009, 03:36 PM
bobc04's Avatar
well i was real low on fluids....didn't even see that there was fluids
Old 04-04-2009, 02:18 AM
libertyforall1776's Avatar
Fluids are like your blood -- keep them maintained or your car will have problems... ;-)
If the trans fluid isn't the problem, then it's likely your trans' clutches/bands.
Quick Reply: wuts wrong with my car!? PLEASE HELP
