wire routing
Old 01-27-2008, 12:25 PM
Default RE: wire routing
The IAC controls idle speed, and won't cause misfires, but will cause improper idle speed & random stalling if the idle speed goes too low. IMO you should take a good look at the ignition system: coil pack, ignition control module under the coils, and the wires and plugs you just replaced, as one of them could be bad or improperly installed.
  #22
Old 01-27-2008, 01:15 PM
3.4CamaroCDOG's Avatar
the packs are good
the wires and plugs are good
i havent checked the ignition module cause its starts first try now that i changed the ECT sensor that controls the fuel
its starts on -5 degree weather first try
if the ICM was out wouldnt it even start right? cause it does.
it also sometimes idles high while im in drive y is that?
this car is actin a ***
ima end up buy this 90 camaro with a rebuilt 305 for $1800 but i didnt really want a older car
  #23
Old 01-27-2008, 03:56 PM
02StanGT's Avatar
ORIGINAL: 3.4CamaroCDOG
It's your IAC. You already knew that, as Pete and myself have told you.
  #24
Old 01-27-2008, 09:08 PM
ok thnxs
buck658
08-31-2011 09:58 PM
mgg4591
82-92 V8 Tech
08-05-2011 06:06 PM
osduck5
06-22-2009 10:13 PM
95redcam
11-25-2006 12:40 AM
kender
10-02-2006 07:45 PM
Quick Reply: wire routing
