wire routing
Old Jan 24, 2008 | 10:21 PM
3.4CamaroCDOG's Avatar
Default wire routing
ok so when u say left do u mean left from inside the car or from facing the car in the front?
Old Jan 25, 2008 | 06:30 AM
02StanGT's Avatar
Default RE: wire routing
Depends on if I'm in the car or not... What are you trying to figure out?
Old Jan 25, 2008 | 10:22 AM
i was tryin to figure which wire goes where on wat side of the engine
can u give me some symthoms that ur wires are routed wrong? will it even start?
Old Jan 25, 2008 | 11:29 AM
02StanGT's Avatar
Are you talking about spark plug wires? If so, I posted this in one of your other threads. Symptoms include misfiring, preignition, probably see poor gas mileage.
Hayne's manual shows this:
front passenger side 1 3 5rear passenger
front driver's side 2 4 6 rear driver's
Odd's on passenger side
Even's on driver side
Old Jan 25, 2008 | 11:43 AM
by the way when u put the wire on the coil pack does the number on the top mean put that wire on the one on the right
or does the one on the bottom mean put it on the right coil thing
example like
2 put 2 on the right coil thing
Old Jan 25, 2008 | 11:50 AM
02StanGT's Avatar
I am unsure of how the coils on the 3.4 are labeled. They may be the same as the 3.8. This is how mine looks...
For example: 2 coil post <---- Plug wire for number2 cylinder goes there
6 coil post <---- Plug wire for number 6 cylinder goes there
On mine, the numbers are right by the coil post.
Old Jan 25, 2008 | 11:58 AM
on mine heres how it is
u got the 2 prone things u connect the wires to
well it got the number goin across the bar thing and they arent next to it
would it hurtthe carto change them around?
Old Jan 25, 2008 | 12:04 PM
here is an example picture
http://www.aa1car.com/library/2004/m...l_ignition.jpg
Old Jan 25, 2008 | 05:14 PM
02StanGT's Avatar
That's how mine are. Looking at the coils from the same angle, odds are on the right off their associated coil, and the evens on the left. I'm telling you that so you can look at your's and use that to hook them up.
Old Jan 25, 2008 | 05:17 PM
The picture you show does not seem rights, the coils are in the wrong position on top of the ignition module.The picture you show does not seem rights, the coils are in the wrong position on top of the ignition module.
The position of the coil on the ignition module indicates which plugs they should connect to.
Here is how they should go:
[IMG]local://upfiles/1197/E3A2435E1B4E4F538232E2FCF21F9734.jpg[/IMG]
