window
RE: window
I depends on what you took apart. Since the door windows are frameless there is a lot of adjustments. And at times it can be a bear. Try to put the bolts back in the old marks. Its hard to tell you what to do when a person can not see what is going on.
Good luck
Good luck
RE: window
Make sure that when you put everything back together that you didn't put something back in wrong ........... something is causing it to be offline which in first thought means that when you put it back together it could have caused something to be " off line "
RE: window
well the only problem is i bought it and the previous owner had already taken the motor out so i out it back in to the best f my knowledge with the help of a site from another post, the window goes up fine, would a shop fix this and how much would it be?
cornmuffin
07-24-2014 10:22 AM
