When changing clutch, I twisted my rear end by accident
Old 03-02-2010 | 03:49 PM
Envisi0n91's Avatar
Default When changing clutch, I twisted my rear end by accident
So the torque arm, driveshaft and now tranny are out and when I had my friends push my car into a parking spot over night I used the E brake instead of the footbrake. now my rear end is supposedly twisted upward with the differential higher than it should be. If I am unable to get it back into place, I am thinking of buying a rear end from a z28 because those came with LSDifferentials, correct? Are they interchangeable?
Old 03-02-2010 | 03:54 PM
What you're saying is the nose of the center section (pinion) lifted? That's no big whoop, you'll be able to rotate it back down and reinstall the torque arm when the time comes. That upward movement is what the torque arm is there to prevent by the way.
what yr is your car? what yr is the rearend u want to use? do u have traction control? the rearends are interchangable but some have a three sensor abs system and some have four, some have traction control and some dont. im asuming u want the disk brakes and posi trac.
Old 03-02-2010 | 04:21 PM
Envisi0n91's Avatar
Not only did it like roll out of place, it bent the shock bolts but I finally got it back to where it was. Good news is that I only have to replace the shock bolts and not the whole thing. Wish me luck lol
Old 03-02-2010 | 04:22 PM
dc14u2no's Avatar
and depending on auto,manual and engine some have different rear gears
Old 03-02-2010 | 04:49 PM
Envisi0n91's Avatar
01 manual "rs" even though im constantly reminded that they didnt have the RS package in 01. I don't know what to believe anymore..
Old 03-02-2010 | 05:22 PM
dc14u2no's Avatar
check your build codes.should be listed inside glove box to tell what rearend gears you have.compare to the donor you are looking at.
Old 03-02-2010 | 05:36 PM
dc14u2no's Avatar
not sure about an '01.earlier codes were ...GU2=axel rear 2.73,GU5=3.23 ratio,GU6=3.42 ratio and G80=axel,rear positraction(limited slip)
Old 03-02-2010 | 05:50 PM
RPO Y3B Rally Sport had dual silver or black Heritage stripes, special grille, RS badging, and Z28-style exhaust. For base coupe and convertible only. Increased V6 power to 205hp. Available directly from SLR
Old 03-03-2010 | 02:16 AM
Envisi0n91's Avatar
YES thats my car! And I always thought it had a little more kick to it than the other 3.8's I've driven!
djsquare1
04-08-2013 01:26 PM
Celticsfan
12-29-2006 11:12 PM
jbassiii
10-02-2006 04:55 PM
chadimus06
09-18-2006 08:12 PM
Quick Reply: When changing clutch, I twisted my rear end by accident
