What else to change?
Old Sep 1, 2011 | 05:40 PM
KiddCamaro's Avatar
Default What else to change?
I have to change my water pump (which is leaking), Tension belt (which is squeaking), and catalytic converter (rattling). I was just wondering if there are any other things I should replace while everythings apart. I was thinking maybe o2 sensor for the cat and also some pulleys for the belt. Im pretty sure all parts in the engine area are stock.
95 v6 3.4l
Old Sep 1, 2011 | 08:01 PM
BasicConcepts's Avatar
Technical User
if you want to just change parts as a preventive maintenance the o2 are cheap, new belt, stat, maybe a good tune up (plugs, wires, pcv, fuel filter, oil change, flush and fill of the cooling system) also you have to pull the rad to get to the pump clean the outside real good and run a garden hose through it for a good 20 min
Old Sep 1, 2011 | 10:21 PM
buck658's Avatar
^what he said
Old Sep 2, 2011 | 11:31 AM
305_camaro's Avatar
March 2012 Ride of the Month
Were you meaning pull the rad hose? cause i never had to pull the actual radiator
Old Sep 2, 2011 | 01:06 PM
buck658's Avatar
^or you could just open the valve at the bottom of the radiator
Old Sep 2, 2011 | 08:47 PM
vanquishfist's Avatar
Wouldn't be a bad idea to change the tranny fluid too.
Old Sep 7, 2011 | 10:31 PM
KiddCamaro's Avatar
would anyone know the part numbers for the following:
-Water pump
-catalytic converter
-thermostat
-Tensioner ( im confused about this one, my mechanic told me i need a need tensioner but I dont know if he means the pulley or belt or both, is this a common problem on this car?)
Old Sep 7, 2011 | 11:58 PM
3800camaro's Avatar
The Tensioner is a whole unit itself. They aren't cheap so ask him of it is the Tensioner or the Tensioner pulley. The catalytic convertor you'll have to find either a highflow or a universal one that will fit the car and pass state emission laws.
Old Sep 8, 2011 | 12:00 AM
3800camaro's Avatar
Also when you do the waterpump get the timing cover gasket and replace that aswell since you'll be right in that area. The timing cover gasket has a tendancy to leak and with most people's luck it's shortly after they replace the water pump.
Old Sep 8, 2011 | 04:40 PM
KiddCamaro's Avatar
The water pump from gm is around $230, but I saw a couple of acdelco water pumps for around $100. Would it be ok to use that?
