voting time kids! ideal cam specs.
ok guys you know what to do! i wanna know which cam specs will yield the most NA power! cam has to be realistic, cant exceed .600 lift also. get your thinking caps on! heres the simulated motor.
L67 heads
custom sheetmetal intake, N* tb
10:1 pistons with l32 rods
completely studded block
FFF longtubes
F body application
automatic transmission.
L67 heads
FFF longtubes
F body application
You're gonna need a larger exhaust duration to compliment those LTs. Scavenging will work wonders for you on those. If you're running a 3600 stall, you can run a pretty sweet cam. BUT... It has to match your heads for optimum power...
So I advise you to get over your hatred of FTV6 and go over there and PM Forced_Firebird about what you wanna do and what your goals are. He can match a cam to a set of heads for you and knows much more than I do about cam/heads. I know a bit but I always point people to somebody more knowledgeable than I. You never know if a person knows wtf they're saying over the internet. They could be bull****ting you.
