VIDEO!!!!
Old May 22, 2007 | 04:35 PM
afar95camaro's Avatar
Default VIDEO!!!!
ok guys, my car has been overheating and such for about a weeka and a half now. i have put pictures and everything else on here but its hard to determine and help anything by pictures. I think i have found the reason my car is overheating and everytime i look there is no fluid in my radiator. i have a video so please watch and i hope we can get this settled. i think the video explans itself as to where i think the problem is. i want to thank everyone in advance. so thanks.
http://www.youtube.com/watch?v=VAwZwbiB1_U
Old May 23, 2007 | 12:03 AM
libertyforall1776's Avatar
Default RE: VIDEO!!!!
You have to compress the sides of the pipe insert to pull out that little pipe branching and check the seal it has, because it's obviously leaking...
Old May 23, 2007 | 06:05 AM
01 Camaro Cp's Avatar
You're right, that green liquid does belong in the radiator.
It appears that the 'O' ring on the bypass tube is bad, and from what I see, the tube itself should be replaced, quite a few questionable areas (Rust).
Old May 23, 2007 | 10:05 AM
i looked at it again and the seal is bad on it. do you know where i can find one of these seals or the whole setup and what will it cost me. and do you know the exact name of the part that is leaking so i can look it up. thanks.
Old May 23, 2007 | 10:14 AM
Look it up with the diagrams here, or easier, call your local Chevrolet parts, get the # & price, then comare to this website, which will be cheaper...
https://www.1stgmcparts.com/partscat.html
1971BB427
Apr 24, 2011 09:58 PM
cbr600rx7
Sep 23, 2009 02:13 AM
troyb
Nov 17, 2006 02:42 AM
