valve stem seals
RE: valve stem seals
I have got the seals that came in the kit. I was doing some other research about putting valve stem seals on both the intake and the exhaust valve's.
Is this a good Idea on the 3.4 or should I just put them on the exhaust valve as normal?.
Does anyone have any other suggestions?
Thanks
Thanks
Pete, can I use the Viton full valve stem seals or should I use the o-ring type on one and the cap type on the other ? This is my first V6 rebuild always worked on the old style SB V8 which was a little different many Yrs ago.
Thanks
Thanks
Pete, when I tore the heads apart they only had seals on one vlave and had no o-rings at all If so was that right? .Do you know of a better Valve stem seal out there or is the Viton seal Ok ?
Pete, P/u another set of Viton seals today. With the Viton (Cap Seal) do i still need to use the o-ring seals on the Int and Exh ? Or can i just us the cap seals?
Thank you for all your help.....
