v6 to 383 stroker
Old Jul 16, 2009 | 09:21 AM
deiselbear's Avatar
Default v6 to 383 stroker
i have a 95 v6 camaro with a 3.4l engine. can i swap it for a carb. 383 stroker. if so what do i need to do it
Old Jul 16, 2009 | 10:20 AM
clyon's Avatar
about 20k in parts to do it properly
Old Jul 16, 2009 | 10:22 AM
Saint_Ali's Avatar
not really...you can build a 383 stroker for 6k,at the highest,or even buy a built one for 4-5k.Now you wont be able to run a carb without cutting the cowl,and you wont be able to run a air cleaner,unless you have like a 6-8" cowl hood.
Old Jul 16, 2009 | 11:37 AM
...And you'll have to change the cradle (front frame structure that the engine is mounted to) over to a V8 style. Plus, your existing transmission won't bolt up to an 8 either. Your rear end won't last a very long time with a 383. So budget for that, or carry a bushel basket with you to pick up the pieces when it goes!
Do you have emissions testing where you're at? If so, you'll have to keep it compliant, which would mean swapping and converting the engine management stuff from a V8 car over to yours.
Old Jul 16, 2009 | 11:53 AM
Not to mention you will have to cut the fire wall so you can fit a distributer in there. You better make sure you got everything installed right cause you going to have to pull the motor to get the distributer back out.
This have been covered like 5000 times. Is the search engine broke again?
Old Jul 16, 2009 | 11:57 AM
02StanGT's Avatar
Seems like these things come in cycles. I think next month is "can I put a Grand Prix GTP supercharger on my 3.8" month again.
Old Jul 16, 2009 | 12:28 PM
This Q&A would have to be considered a form of "regifting" of a thread subject.
Add it all up (money, time, parts hunting, aggravation, pulled hair, busted knuckles), and you might find out it'll be a lot cheaper and easier to just buy a V8 car instead.
Old Jul 16, 2009 | 12:35 PM
Get a 3rd gen. They mod way easier!
Old Jul 16, 2009 | 12:37 PM
Saint_Ali's Avatar
OP never said what generation 383 we are talking about either,that could help
Old Jul 16, 2009 | 12:39 PM
Oh crap! I forgot to add swear words to the shopping list.
You're going to need a ton of them, so start saving them up now!!!
