TWIN TURBO HELP
TWIN TURBO HELP
im going to be getting a full twin turbo set up for my v-6
however i was wondering if anyone could instuct me or tell me how to set up the custom exhaust
i have some a ideas and a few amauters but i figured id see if anyone knew anything more than us
thanks
thanks
RE: TWIN TURBO HELP
Talk to these guys. They are the only ones that I know of that have done a TT setup in a 4th gen V6. It's on the extreme side, but they can give you an idea of what is needed. I hope you have very deep pockets, it won't be cheap.
https://www.flp2win.com/store/
RE: TWIN TURBO HELP
Well, the theory behind a twin turbo setup is that a large turbo offers peak performance at high RPMs, while small turbos max at low RPMs. If you combine the two, you have an entirely new threshold that you have to play with. This is the idea that is backing each and every transfer truck on the road today. 95% of them are running twin turbo setups, and those that aren't are running factory modified DOHC single turbo engines.
