Turning signal doesn't work.
Old Aug 6, 2010 | 01:40 PM
better give a call to the local parts store and see what they charge.
Old Aug 6, 2010 | 02:06 PM
BoricuaHec01's Avatar
K, so I called Pepboys and they have it in stock for 6 dollars lol. I can't believe I had this done two years ago and got charged 50 bucks when I couldve just done it myself lol.
Old Aug 6, 2010 | 03:20 PM
MB1969's Avatar
There is a box next to the radio the has something to do with the flashing light too or blinkers that something gets hot and makes the blinker not work. It's black and 3x4 square box replace it to if you still have the problem.
Old Aug 6, 2010 | 04:28 PM
Dammit, I knew their might be another problem and it might not be the flasher cause the flasher is about two years old and the problem I have now was different then when I replaced the flasher. The first problem was the green indicator light left and right will just stay solid green but had flasher replaced, now nothing at all happens so was thinking it might not be the flasher after all. FML.
Old Aug 6, 2010 | 05:19 PM
have you checked to see if you have a burnt out bulb. bad bulb will cause that side not to blink. check the bulb in the dash to make sure its not bad.
Old Aug 6, 2010 | 05:41 PM
The green bulb inside the gauge?
Old Aug 6, 2010 | 05:43 PM
I don't know how to take my dash out like that. I'm hoping its just the flasher.
Old Aug 6, 2010 | 06:19 PM
yes bulb in the dash and check the bulbs in the tail and front blinkers if one of them is failing the flasher will not blink. its not that bad getting the gage cluster out. time consuming.
Old Aug 6, 2010 | 06:52 PM
MB1969's Avatar
I will send a picture of the box i'm talking about and the part number for it give a minute a two thks..MB1969
Crazy_Mike
Aug 15, 2014 08:29 PM
Big Zeus08
Sep 15, 2012 12:15 PM
cbruce31
Feb 10, 2011 10:51 AM
cbruce31
Dec 13, 2010 02:52 PM
BoricuaHec01
Jun 30, 2008 11:37 PM
