Is this true?
RE: Is this true?
Manuals are lighter too. They have different rates of weight transfering too. So if you give two IDENTICAL I mean Identical in every fesable way on IDENTICAL launch surface yes the stick would be faster. It has a lower co-efficient of friction internally. There is less parasitic loss since it doesn't have a pump either. The hard part is dropping the clutch at just the RPM w/o spinning the tires too much and to get it to actually spin.
RE: Is this true?
For the later model camaros, especially the Z28 and SS's, yes, the autos are quicker off the line. Like stated above, the driver makes a drastic difference. But if you put to drivers of the same skill level (assuming their not professional, lol) then yeah, the autos have a very small advantage.
RE: Is this true?
All things being equal automatics will get the jump on a stick off the line. However, the automatics sop up a lot of power and the stick car usually catches up near the finish line. If you got power to spare, the automatic is more consistent and probably a better choice, but again, a lot depends on the driver.
