transmission swap-info needed
Old Jan 20, 2010 | 08:02 PM
cschues80's Avatar
Default transmission swap-info needed
Im planning on swapping an automatic transmission with a manual tranny in my 97 RS. Ive heard that the manual transmission is bigger than the auto and that i might encounter problems. if anyone has any info from personal experience it would greatly be appreciated
Old Jan 20, 2010 | 09:21 PM
That sounds backwards. The floor for the manual is different. to do a nice job you should weld in the floor right around the shifter. It has a hump to mount your shifter booth to. What is your plan for the computer? Your computer is hooked to your automatic. You do know you need a T5 from a Camaro? Do you have a doner car. Your going to need a lot of parts.
Old Jan 21, 2010 | 10:41 AM
cschues80's Avatar
OK do i need to weld the floor around the shifter tho? And i don't have a doner car. i still need to find one. And cant i just hook the computer up to the manual tranny? and a T5 is the only transmission that will work wit that type of application?
Old Jan 21, 2010 | 11:24 AM
No, I said if you want to do a nice job you need to weld it up. You could use epoxy or you could just figure out another way to keep junk and gases from coming into the car.
No there is nothing to plug to. The computer will know it is not pluged into anything and will set a check engine light. The computer controls the shifting in the automatic trans.
Not just a T5 but a T5 from a Camaro. A T5 from a mustang or even a S10 will not work right.
REDREDSS
Apr 9, 2012 12:18 PM
Drache
Mar 29, 2011 02:28 AM
abcer
Nov 5, 2009 05:51 PM
kona1
Oct 23, 2008 09:23 PM
tall
Mar 6, 2007 05:31 PM
