Transmission
Hey ive had my camaro for a while now and i wanted to start building it so i figured id start with the clutch since its about to go. I was wondering if there were any stage 2 or 3 kits for the 3.4 and if not if a kit for a 3.8 would work the same cause im not sure if they were the same transmission or not. Suggestions would be great, thanks
I'm not sure what you mean by "building it", but unless you plan on making it into a hot rod, I believe the stock type clutch will work fine. Also it would be a good idea to beef up your rear end before going nuts with the engine. I would hate for you to have a super engine with your Stage 4 clutch, but a weak rear end. Kind of asking for trouble.
dsinclair999
Feb 21, 2011 11:24 AM
