trans promlems! ideas please
Old May 25, 2011 | 03:49 PM
rayray3866's Avatar
Default trans promlems! ideas please
I've got a 96 RS camaro 3.8 with auto trans. last sunday i was driving home and i noticed it started shifting hard into 4th. monday going to work the same thing was happening. on the way home it started jumping from 3rd to 4th repeatedly around 40-45mph. tuesday through today hasnt jumped gears but still shifts hard into 4th. any ideas?!?! i havent had any problems with it prior to sunday. and also when im cruising highway speeds 65-70mph the rpms are about 2,500 so i'm thinking i lost overdrive. i dont ever remember the rpms being so high at cruising speeds. any ideas please!
Old May 25, 2011 | 04:05 PM
rayray3866's Avatar
or is 4th gear overdrive?
Old May 25, 2011 | 04:51 PM
4th gear is overdrive, 3rd gear is direct drive, 1st & 2nd gear are underdrives.
Old May 25, 2011 | 06:55 PM
3800camaro's Avatar
I think you are having solinoide problems. Normally it's just reverse that goes when your tranny goes. But bad solenoids will cause jerky shifting or high revving before shifting.
Old May 25, 2011 | 07:04 PM
What? Reverse requires the highest line pressure to work but it is pretty rare for a car to show up with no reverse and forward still working.
The most common issue that will cause hard shifting is a sticking accumulator or a broken accumulator spring.
olered
Nov 13, 2011 08:52 PM
libertyforall1776
Sep 13, 2011 12:28 PM
SNFO97ss
Jun 12, 2009 08:04 AM
camaro2323
Jun 18, 2007 04:50 PM
v10viper04
Oct 12, 2006 09:33 PM
