Traction Control
Old Sep 23, 2008 | 07:37 PM
02CamaroV6's Avatar
Default Traction Control
I have been trying to find out how to turn off the traction control, I am not sure how to do it. anybody know how?
I have a 2002 V6.
Old Sep 23, 2008 | 09:58 PM
02StanGT's Avatar
Default RE: Traction Control
There should be some rocker switches above the radio.
Old Sep 24, 2008 | 08:19 PM
02CamaroV6's Avatar
Oh, well theres a switch for the fog lights, then there is a place where a button could go...
Old Sep 24, 2008 | 08:44 PM
02StanGT's Avatar
Have you looked behind the radio bezel to see if the switch (or a plug without a switch) is behind there?
Old Sep 25, 2008 | 06:36 AM
02CamaroV6's Avatar
I havent looked there, ill see if that is where it is at.
Old Oct 1, 2008 | 08:03 PM
02CamaroV6's Avatar
Well, i still havent found out how to turn off the traction control any more suggestions?
Old Oct 1, 2008 | 08:12 PM
02StanGT's Avatar
You sure you have it? Just read a few sites that said the switch is in front of the shifter, near the lighter.
Old Oct 1, 2008 | 10:17 PM
evilkal's Avatar
1999 models came standard with traction control and mine does not have a switch....
Old Oct 2, 2008 | 06:34 PM
Whitehoss02's Avatar
ASR - The acceleration Slip Regulator is located next to the fog light switch above the radio Like 02stanGT said - if the button is not there check your manual for ASR it should tell you where to find it - I have a 02 same model - it came with the switch.
typip111
Jul 21, 2011 07:38 PM
Combat_Chuck
Apr 19, 2008 11:03 AM
EggboaT
Apr 19, 2007 04:48 PM
Puck90a
Jan 29, 2007 11:58 PM
KoRN_Munky
May 31, 2006 01:30 PM
