Timing chain cover
Old May 2, 2013 | 08:38 PM
  #21
Chevy101's Avatar
I replaced the tensioner so I only have one plastic elbow. Ill be sure to look at that.
Old May 2, 2013 | 10:47 PM
  #22
Massey's Avatar
The tensioner has 2 plastic elbows that go into it. How do you get away with only one? You should have one per heater hose and one goes into the water pump the other goes to the intake.
Massey
Old May 3, 2013 | 12:07 AM
  #23
fbodyrs96's Avatar
The early 3.8's only have the lower plastic elbow, it's all one piece of aluminum.
Old May 3, 2013 | 05:25 AM
  #24
Chevy101's Avatar
The replacement I bought actually had the lower elbow molded into the assembly
Old May 3, 2013 | 06:22 AM
  #25
Chevy101's Avatar
Which dampener do you guys think is best?
Old May 3, 2013 | 06:06 PM
  #26
Massey's Avatar
Any Damper for the Series 2 and Series 3 engines should work. There is a design difference between the FWD and RWD dampers but GM lists the parts as interchangeable. DO NOT use the damper from the supercharged engines those are different. I dont know what is different but they have a different part number and they are not listed as interchangeable.
Massey
Old May 3, 2013 | 08:18 PM
  #27
Chevy101's Avatar
Thanks Massey. Am I going to have to drop my oil pan?
Old May 3, 2013 | 08:51 PM
  #28
fbodyrs96's Avatar
no....
Old May 28, 2013 | 01:45 PM
  #29
Chevy101's Avatar
What do guys recommend to clean off the old timing and water pump gaskets?
Old May 28, 2013 | 02:41 PM
  #30
brake cleen works
