Timing chain cover
Old May 1, 2013 | 04:06 PM
Chevy101's Avatar
Default Timing chain cover
I have a 98 camaro with the 3.8L and the timing cover is leaking. I was quoted at $440 at my mechanic. How hard is it to replace this?
Old May 1, 2013 | 05:35 PM
Sicilian's Avatar
I don't know much, but from my skill, it goes like this.....
remove neg batt cable, remove belt, remove crank pulley, remove water pump(will have loss of fluids, recommend a rad drain first), the water pump bolts are also bolts that hold parts of the timing chain cover in place, remove timing chain cover. make sure all surfaces are clean and maybe some thread lock on all the bolts, then replace gaskets on the cover and pump, put back together in reverse.
If I am wrong in anyway i'm sure somebody will correct me with no problems. Hope this helps, I will try to add a link aswell....
Old May 1, 2013 | 05:37 PM
Sicilian's Avatar
oooops, you have a 3.8l not a 3.4l very sorry for that!
Old May 1, 2013 | 06:26 PM
Massey's Avatar
Are you sure it is the timing cover? If it is coolant it is not usually the timing cover it is usually the plastic hoses between the water pump and intake. If it is oil it could be the seal for the harmonic balancer. Clean the area really good and drive for a few to check the actual place of leaking.
Massey
Old May 1, 2013 | 06:38 PM
Chevy101's Avatar
It's definitely coolent. The plastic elbows were replaced last year. My mechanic looked at the car today and told me it was the cover
Old May 1, 2013 | 06:53 PM
9434V6's Avatar
Hey, I had a question on your instructions considering Im doing mine as well soon. When I take off the crank pulley, will I need to replace the front main seal? Or does just the pulley come off, and thats enough? Ii already planned on ordering the timing chain, sprockets, cover gasket, and water pump gasket. just making sure i dont need anything else.
Old May 1, 2013 | 08:52 PM
fbodyrs96's Avatar
don't forget you have to replace the crank bolt also, its a one time use bolt. you will also need some bolts for the crank pulley, none of the pullers you rent will come with the right bolts to pull it off.
no you dont have to replace the main but it makes since to cause you will have it off.
its very time consuming an a ***** sometimes, it took me and my dad with a 4 foot cheater bar to break my crank bolt losse.
Old May 1, 2013 | 10:43 PM
9434V6's Avatar
Thank you for the advice. I did the front main seal once before on my old camaro, and did the water pump gasket already on this one. My dad has some special tool that you crank the, well, crank bolt off with. but new hardware would probably be a good idea. i just remember that front main seal was a horrible disaster to do last time and was hoping i could avoid it. but if its coming out anyway, might as well do it.
Old May 2, 2013 | 09:17 AM
Chevy101's Avatar
I have a guy telling me that coolant doesn't run anywhere past the timing cover gasket. Can anyone help me out?
Old May 2, 2013 | 09:30 AM
please do not jack threads.
