tick tick tick
Old 09-13-2007, 01:45 PM
joeyninetoes's Avatar
Default RE: tick tick tick update
ORIGINAL: cplthomas
When is the last time the fuel filter was changed?
3000 miles ago
  #22
Old 09-13-2007, 04:32 PM
a flashingSES light means misfire doesn't it?
  #23
Old 09-13-2007, 04:45 PM
usarmyrangrs's Avatar
A flashing SES indicates a misfire or condition that could rapidly and severely damage the catalytic converter.
Yes.
  #24
Old 09-14-2007, 08:57 AM
had SES checked today.
misfire 5
darn
  #25
Old 09-14-2007, 08:43 PM
srmrvette's Avatar
Don't know if this will help, but on a long road trip I noticed a slight hesitation on acceleration. Then the ses light came on. To shorten this up, the car finallyran rough and set a code. It was misfire cyl 1. Turned out to be a bad spark plug wire, and replacing it solved the problem. BUT, in checking things over we heard this very distinct clicking noise, which was the spark discharge from the bad wire right at the coil for cyl 1. Quite loud with the engine in idle and the hood up, but not something someone on the street would notice as you frove by.
  #26
Old 09-15-2007, 07:22 AM
that makes sense
my #6 wire was totally broken
however, it never really made a secondary noise, atleast not that i'm aware of
man,
thanks everyone for your responses
i sure am glad i found this forum
  #27
Old 09-15-2007, 07:49 AM
check and see if your plug wires are on good
i had a clicking noise and it was because a wire was loose from a plug
  #28
Old 09-15-2007, 07:58 PM
can anyone tell me what the placement order of the plugs are
like
drivers side front to back 4-5-6-
pass side " ' " 1-2-3
i was trying to get to them from the top today. WOW
whatever the one is in the middle
it's under the exaust manifold
  #29
Old 09-15-2007, 08:58 PM
Chappie99's Avatar
A good way to find out if your wires are arking out is to at night with no lights on. Take a spray bottle full of water, spray a mist over the engine compartment and you will find the arking wire by seeing a spark.
  #30
Old 09-16-2007, 06:05 PM
ORIGINAL: joeyninetoes
like
anyone
Quick Reply: tick tick tick
