Tick on startup?
Old Apr 6, 2012 | 11:44 AM
TheArtfulLodger's Avatar
Default Tick on startup?
When my Camaro has been sitting for a few days (I'm in college and live on campus, that's why it sits that long), I'll get a tick on startup. It increases in frequency as the RPM climb, and then when the engine is warmed up, it goes away. Any ideas? The only thing I can think of is that it might be a lifter, but I can't think of why I think that, really. The car has 88K on it, and a 3.8. Any thoughts/ideas?
Old Apr 6, 2012 | 12:00 PM
A couple possibilities are a gunked or gummed up lifter, or oil isn't making it up through the pushrod right away to lube the rocker arm.
Been there, had that, and changing to synthetic oil gradually cleaned out the crud in the engine (as it's known to do), and got rid of the noise.
Old Apr 6, 2012 | 12:23 PM
PiN's Avatar
PiN
I would try 69's suggestion first, your could get lucky and have a plugged lifter.
I had the same problem on mine and turned out to be a failing oil pump (which gm's in my experiance seem to have issues with them).
Old Apr 7, 2012 | 02:56 PM
I'll definitely hope synthetic will clean it out first. SES light came on yesterday over an exhaust leak/O2 sensor.
djsquare1
Apr 28, 2013 09:19 PM
CoyotesLaugh
Nov 29, 2010 06:09 AM
shawnz_90
Apr 17, 2009 09:49 AM
creck
67-69 V8 Tech
Mar 18, 2008 06:55 PM
joeyninetoes
Sep 16, 2007 06:06 PM
