thinking i have a gas leak
No common issue, infact I would say its rare. It should set a check engine lite. High pressure fuel that is leaking is very dangerous you shold track this down.
i would say if your smelling only when its running you may be running way rich. check the exhaust for gas smell. if not that check your fuel pressure regulator and your evap system and gas cap. should not be the fuel line as its under pressure all the time. at least its supposed to be, so check the fuel pressure as well. there is a sticky at the top in the lt1 section for evap.
https://camaroforums.com/forum/lt1-lt4-tech-9/testing-evap-system-51219/
