tail lights
Old 12-06-2009, 07:39 PM
thetal1's Avatar
Question tail lights
will 98-02 tail lights fit 93-97 camaros?
Old 12-06-2009, 07:44 PM
Blasko's Avatar
I had to notch a couple of the tab openings on the housings a little differently because the light sockets have different tab configurations. But otherwise, it's a simple bolt-on changeover.
I haven't done this myself, But I've heard that it is simple and only requires minor wiring changes to the turn signals.
Old 12-06-2009, 07:45 PM
thetal1's Avatar
so the housings wont fit?
Old 12-06-2009, 07:55 PM
Blasko's Avatar
Hopefully this helps
The 92-97 =LT1 Tail lights ans
The 98-02 =LS2 tail Lights
LS1 Tech threat on Tail Lights
Old 12-06-2009, 08:01 PM
thetal1's Avatar
this is why i ask
im buyin aftermarket tail light housings and i cant find the ones i want for my year
Old 12-06-2009, 08:21 PM
Blasko's Avatar
Ah, I See.
they will physically fit, but the bulbs are different on the LS1 Style.
a quick trip to your local junkyard will have that problem solved in no time.
All you'd need is the bulb holders for the LS1 style.
Can anyone Verify this?
I'm not 100% sure, But I think This would work.
Old 12-06-2009, 08:44 PM
thetal1's Avatar
alright thank you
Old 12-06-2009, 10:01 PM
They will work, I've done it. But the bulb socket lock tabs to housing openings line up slightly differently. So with a utility knife, you need to alter the tab openings on the new housings, and/or trim one of the tabs on the sockets a little. You don't need to change your sockets.
Old 12-07-2009, 01:17 PM
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
I went from 98-02 to 93-97. It was a little more work to convert, but I think it should be easier going the other way around.
Old 12-07-2009, 01:24 PM
thetal1's Avatar
lol i just ditched the whole converting thing. i got the right lights for $86. Now all i need is a smoked 3rd brake light for $40 (after shipping which will be hard to find) and the exterior lighting in my car will be done
Quick Reply: tail lights
