TACH HELP!!!!?
Old Aug 25, 2008 | 11:40 AM
camarofreak1990's Avatar
Default TACH HELP!!!!?
ok i got a tach from sunpro and ive got evrything mounted and all my wires done EXCEPT one. the green one wthich provides the tach with the PRM signal. it says u hook it to the white wire coming out of the powertrain control module located behind the passenger side strut tower. the only problem is the are more than one white wire. does anyone know which one it is? or can help me? (it also says the pin ID is 8)
Old Aug 25, 2008 | 08:10 PM
magnum041's Avatar
Default RE: TACH HELP!!!!?
if you remove the neg cable from battery and remove the plugs from pcm 7mm headed bolts there are numers at corners of plug sokets to go by then tap in to pin id 8 reinstall and conect batt neg.
mikes68
May 17, 2014 06:50 PM
94z28chevy
Feb 1, 2009 04:50 PM
FunkyColdMedina
Sep 19, 2007 09:26 PM
3RDGENZ28TX
Aug 20, 2007 08:08 PM
Raven91Z28
Jun 19, 2007 07:37 PM
