Synthetic Oil ?
Old Aug 19, 2010 | 10:52 AM
Chevy101's Avatar
I have almost 200k on my 98 camaro and have only put in mobil 1. Since it the pan gasket leaks I put in 10w40 and that pretty much slows the leak to almost nothing.
Old Aug 19, 2010 | 05:09 PM
ChappieJR's Avatar
Walmart is only $21 bucks,, hes right.. But I also use the FRAM 3980 filters (which are for a 4.3) cuz they hold more oil.. SO i had to buy an extra quart. So its about $28 bucks. I also noticed it makes my engine run about 6-7 degrees cooler.
Old Aug 19, 2010 | 05:40 PM
Barkat's Avatar
So, your running one of the best oils made, and ruining it with one of the worst filters made?
Old Aug 19, 2010 | 08:43 PM
trigger987's Avatar
That brings me to what i forgot to mention in the post, what oil filter should i use?
Old Aug 19, 2010 | 08:48 PM
osduck5's Avatar
I am using Purolator or AC delco myself.
Old Aug 19, 2010 | 10:55 PM
I use the STP filter, which is the same as an AC Delco Ultraguard, but costs just a tad less.
Everything you wanted to know about oil filters but were afraid to ask: http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilters.html
Old Aug 22, 2010 | 06:05 PM
ChappieJR's Avatar
its the ultra guard6X.. guess i wont be using them no more..
Old Aug 22, 2010 | 07:51 PM
microkid's Avatar
March 2011 ROTM
Technical User
if the car leaks or burns oil though, i strongly recommend sticking with conventional. the synthetic has smaller molecules, which in turn leads to larger leaks and faster burn off. i run mobile clean in my dd, which has 184k miles. ive tried castrol in it but it burns off too fast, and the engine is a bit noisy with it (as is my bike).
LETSROC
Sep 24, 2010 08:31 AM
ztothe28
Apr 22, 2007 07:20 PM
Z28man
Jun 10, 2006 02:02 PM
drummersdad
82-92 V8 Tech
May 4, 2006 08:30 PM
drummersdad
Apr 24, 2006 03:30 PM
