Swapping out the steering column
Old Feb 19, 2008 | 07:58 PM
kahzmo99's Avatar
Default Swapping out the steering column
Can anyone point me to a reference or a link to something that might offer me some guidance on swapping out the steering column with a replacement one for the 3.4 V6? I have heard that it's a relatively simple process but figured I should have a reference handy when I start in case I hit any road blocks...
Anyone?
Old Feb 19, 2008 | 08:21 PM
importmd's Avatar
Default RE: Swapping out the steering column
Its very easy, remove the bolt from the column and the steering linkage right under the brake booster, there should be a plastic piece covering it up, it just pops off. the remove the plastic knee panel thats under the column. then remove the 3 bolts that hold the column to the fire wall, followed by the four bolts holding it to the dash. once its loose, you can pull it down and out and unplug the connecters that are mounted to the top of the column. pull it out. should take 10 minutes
Old Feb 19, 2008 | 10:20 PM
kahzmo99's Avatar
That's fantastic! Thanks much!!
MJTate
Jun 25, 2013 06:26 PM
demonfork
Jul 8, 2010 07:15 PM
ILUVMY89
Jan 2, 2009 10:54 PM
Arizona Camaro
Oct 26, 2007 04:13 PM
