Stig's Modification Guide for the 3800 V6
Old Feb 18, 2008 | 12:00 AM
TheStig's Avatar
Default Stig's Modification Guide for the 3800 V6
This is my guide on how to modify your 3.8 V6 F-body. Whether you just want a few extra ponies out of your daily driver, or a full-blown racecar running 10s, I will cover everything. I have broken this into many sections.
-Intake
-Exhaust
-Ignition
-Drive train
-Internals
-Nitrous
-Forced Induction[/align]
Intake
First thing I will cover is the Intake. It is probably the first mod you should do to any car seeking more power or better gas mileage. An intake will feed more air into your engine and create more power and even give you better gas mileage.
If your have a 95-97 3800, you will want to buy a new intake. There are several different options, to fit any budget. You can find these intakes on several sites, including K&N and Ebay. It is a debated subject on whether or not ebay intakes are any good. But as long as you have a strait smooth intake, sending cold air to your throttle body it is good. You can buy a cheap ebay intake and attach a K&N cone air filter and have a decent set-up.
K&N intake for the 3.4l V6: http://i.b5z.net/i/u/509876/i/KN5730101.jpg
SLP intake for the 3800 V6: http://marylandspeed.com/images/21013.jpg
Ebay intake for the 3800 V6: http://www.imagestation2.com/1ch/pic...L_halfFull.jpg
The 98-02 Camaros have a very different intake system than their 93-97 counter parts. They actually have a very good intake system that does not need to be replaced. However, there are a few modifications you can do to get a few more ponies out of them. The air lid can be replaced for a whisper lid or you can remove the baffles from the top of the lid yourself. Removing the baffles will let more air through, however the whisper lid is still a better set up as it has still allows more airflow. You should also replace your paper air filter for a K&N air filter. Something you may want to consider doing is removing the silencer from your intake. It is the big plastic bubble like object that sits behind the air lid. Replacing it is not necessary, however it will provide better airflow. You would have to replace the silencer with a custom setup. Usually people use PVC pipe or any tubing that will fit.
Whisper lid: http://www.whispermotorsports.com/fbody.html
K&N Air filter: http://store.summitracing.com/partde...p;autoview=sku
Another modification you can make to the intake is a “ram air” setup to get more, cold air to the air box. SLP makes a setup for the f-body that fits in front of the top of the radiator and forces cold air into the bottom of the air box. They sell it for about $140, however, if you are the “do it your selfer” you may want to consider making your own. You will need just plain sheet aluminum. Links are provided bellow for both.
Home made kit: http://www.fullthrottlev6.com/forums...ad.php?t=27005
SLP kit: http://store.summitracing.com/partdetail.asp?autofilter=1&part=SLE%2D21033&a mp;N=
[URL=http://store.summitracing.com/partdetail.asp?autofilter=1&part=SLE%2D21033&a mp;N=700+4294908216+4294
Old Feb 18, 2008 | 12:02 AM
TheStig's Avatar
Default RE: Stig's Modification Guide for the 3800 V6
I will be adding more to this as time goes on and will cover everything.
Old Feb 18, 2008 | 12:10 AM
The Banks's Avatar
Looks like it'll be a nice sticky when its all done.
Old Feb 18, 2008 | 12:11 AM
ninetysixyenko's Avatar
oooh!!! stig's gonna out do Badinfluence!!!
Old Feb 18, 2008 | 01:34 AM
libertyforall1776's Avatar
Here's the SLP intake for the V6 3.4L:
http://www.exoticperformanceplus.com....html?item=531
Old Feb 18, 2008 | 06:40 PM
98RCMARO's Avatar
Great guide, I was hoping you would be the one to write a nice in-depth guide!
Old Feb 18, 2008 | 08:01 PM
skylinrcr01's Avatar
i bought an ebay intake. it was a real pain to put on, but it works really well.
Old Feb 20, 2008 | 10:09 PM
TheStig's Avatar
ORIGINAL: 98RCMARO
thank you, yep, I will add more as time goes on.
Old Feb 21, 2008 | 11:19 AM
BigNic's Avatar
4' 11" 117 lbs of fury!
we should hop so sitg so far you shown everybody how to add 5 hp
Old Feb 23, 2008 | 03:24 PM
TheStig's Avatar
ORIGINAL: BigNic
we should hope so, sitg so far you shown everybody how to add 5 hp
Its updated, Smart ***
