Starting to hate camaros
Old Dec 18, 2010 | 10:33 AM
dogdog130's Avatar
Default Starting to hate camaros
Ok well i have had this car for a week and it is falling apart on me already (gf is threatening me now while i type ) here the list any ideas plz do too
it is a 3.4 lit v6,1995 camaro manual
what i have done to car. Oil change high mileage ,air filter,fuel filter,sea foam,gas cap
things wrong
1.check engine light comes on and disappers random times makeing gas smell like gas
2.gas coming out of filler
3. Had hard clutch when went into work not goes to floor
4.oil pressure went from 70 to 30
any ideas how to fix this would be great they want 150 to check my obd sense it not in there system
Old Dec 18, 2010 | 10:39 AM
montecarlogrrl's Avatar
Where did you take it to check the code? From what I understand most of the big chain auto parts stores read codes for free.
Old Dec 18, 2010 | 10:40 AM
dogdog130's Avatar
The for obdii i have a obdi
Old Dec 18, 2010 | 10:43 AM
evilkal's Avatar
His car is an OBD1 car. They would need an OBD1 reader. However I would never pay 150 for a single code readout when I can buy a reader for that amount.
Considering you've given me very little to work with here's all I can do. Tell me how the car acts when driving.
Gas comes out of the filler cap WHEN? Could be an EVAP problem.
Clutch issues could be explained by a master or slave going bye bye. How many miles are on the car?
Does the oil pressure do that instantly or as the car warms up? Warm, at idle, your car should be around 25-35 psi oil pressure depending on what weight and whether it's synthetic.
Old Dec 18, 2010 | 10:47 AM
95 is obd1 with obd2 plug. you can make a adapter so obd1 scanner will work. test your evap system. https://camaroforums.com/forum/lt1-lt4-tech-9/testing-evap-system-51219/ it sounds like the vent valve may be pluged or stuck/jammed or gas cap is shot.
Old Dec 18, 2010 | 10:48 AM
dogdog130's Avatar
car drives great could not complain about that , yea i figured the master cylinder it just weird before work it good after bad and oil it be good for like 10 min sitting then it drops. gas comes out gas cap when check engine light comes on
Old Dec 18, 2010 | 10:51 AM
I know he has obd1 I just thought they read everything. Well that sucks. I'd just buy a code scanner for that price then you have it whenever you need it. Good luck with the car... Listen to craby and evilkal, they know their stuff.
Old Dec 18, 2010 | 10:55 AM
get a new gas cap to start with. as for the oil pressure,what is the pressure at idle and at 2k rpm when cold and at operating temp. what wt of oil did the previous owner have in it and what wt of oil did you use? a drop like that would be expected if it had 20w50 and you put 5w30 in it or if it had a additive like stp in it before you changed the oil. like kal said the clutch could be the master or slave cylinder or could be leaking fluid line or no fluid.
Old Dec 18, 2010 | 11:01 AM
oh i see you got the new cap.
Old Dec 18, 2010 | 11:03 AM
dogdog130's Avatar
got new gas cap yesterday oil is same guy got the same walwart package couldnt change it bec i live in a apartment complex and im going to bleed the clutch system today
