Spark Plugs3.4
Old Jan 6, 2008 | 12:54 AM
3.4CamaroCDOG's Avatar
Default Spark Plugs3.4
Can anyone tell me where my spark plugs and wires are located and how to get to them please. My car is misfiring and i wanna check and make sure the wires are ok
Old Jan 6, 2008 | 02:05 AM
02StanGT's Avatar
Default RE: Spark Plugs3.4
Locate the exhaust manifold (header) on each side. There will be three wires spread evenly apart, located below the manifold. The wires are your plug wires (thicker than any other wires), and spark plugs are screwed into head below the manifold.
Old Jan 6, 2008 | 02:35 PM
95sport's Avatar
I changed mine recently,the ones on the passenger side are a pain,mainly the one right under the egr[:@].
Old Jan 6, 2008 | 03:44 PM
i just checked my spark plugs on the driver side and 2 were white-ish and i just had them changed in may/june.... has anyone ever heard of autoline plugs? those were in there....... the shop did it when they fixed my lifters and heads..
wat is the best type of plugs to put in it... the wires are ok just the plugs... i tried to get to the plugs on the passenger side i could reach one from the top but i guess ima have to go under to get to the rest of them.
FYI. I dont have unlimited funds lol
Old Jan 6, 2008 | 08:06 PM
02StanGT's Avatar
ORIGINAL: 3.4CamaroCDOG
You said two were white, which usually indicates a lean condition (not enough fuel for the air entering combustion chamber). You said it misfires sometimes, and with the condition of those two plugs, leads me to believe the injectors for those cylinders are plugged or faulted.
http://www.verrill.com/moto/sellingg...colorchart.htm
This site shows plug tips, and explains what they mean. Plugs can tell you alot about how your engine is running.
Old Jan 6, 2008 | 09:39 PM
OMG i put the plugs back in and now my car is not running right
my acceleration is not that good all i did was check them and put them right back in
wat could be wrong?
do i have to reset my computer on it?
cause i unpluged the battery and hooked it back up
Old Jan 6, 2008 | 10:28 PM
02StanGT's Avatar
Did you hook the wires back up to the right plugs? Are the wire on good? Just a couple things to check...
Old Jan 6, 2008 | 11:33 PM
im pretty sure they are but ill double check tommorrow before school
i unplugged my battery and replugged it does that reset the computer?
and how tight do they have to be?
Old Jan 7, 2008 | 12:54 AM
02StanGT's Avatar
Should hear/feel them kind of "pop" on there.
Old Jan 7, 2008 | 12:02 PM
they popped on but was i suppose to unhook the battery ima replace them when i get some money
