SES light will not go away!
Old May 21, 2008 | 10:07 AM
02CamaroV6's Avatar
Default SES light will not go away!
Ok, for awhile now my SES light has been on and i have replaced almost everything i thought be the problem, im not sure what the exact code is but it has to do with a catalyst problem. I have replaced all the sensors, i replaced the catalytic converter, changed o2 sensor, and the problem still persist. One thing is that this happened when i got my camaro back from the shop, i had a SS hood installed. This hood is not set up to a CAI or anything, but it can be functional. could the problem be that more air is just pointlessly coming in my engine from the scoop? im not sure what the problem is, please help.
Old May 21, 2008 | 10:37 AM
blackz87's Avatar
Default RE: SES light will not go away!
Disconnect the battery for 5 minutes to reset the computer. This should remove all the old codes stored there.
Old May 21, 2008 | 12:33 PM
02CamaroV6's Avatar
i have a device for reading the codes, and everytime i check them, its the same one. I also erase the codes after i check them but the SES still comes back on after like 20 miles.
Old May 21, 2008 | 12:56 PM
baseballer91's Avatar
i have teh same problem..
my code is
P1416
(AIR)
so my solution is to get a tuned computer to remove the AIR system... you should try the same...(well aimed at whatever your problem is)
Old May 21, 2008 | 01:24 PM
02CamaroV6's Avatar
thats a good idea, i might have to do that.
Socom
Nov 9, 2013 01:41 PM
Rent
Apr 22, 2013 11:08 PM
hpd218
Aug 24, 2010 12:05 PM
evilbeef54
Jul 27, 2008 09:47 PM
dustinb
Oct 1, 2007 06:58 PM
