Security Warning Light
Hello all Camaro Gurus...
Just a quick question, I have had the 'security' light on my Camaro for some time and would like to fix that problem.
My first question is why would the light be on? I have no security system in my car and my engine starts fine with my keys.. A few years back I did get a new key code when my starter went out I think... just curious to this diagnostic.
As for fixing the situation for now, could I pull a fuse that that is in the driver side panel?
Let me know with any suggestions, thank you all..
Brad
Brad
Your security light can come on for a few reasons. Like 3800 said, bad programing. Your VATS could be bypassed. Those are the most common issues. If you got a new key with a different chip then you should not be able to start the car unless the system has been bypassed.
What year is the car? I have schematics for a 2000 Camaro that I could send you. I found that my 99 is very close to the 2000 as far as wiring goes and I dont think there were too many changes between 2000-2002. I know that the 93,94,95,96,97, and 98 are all almost totally different from one and another.
Massey
Massey
unfortunately, it's a 97 Camaro. I will def go an check it out at the dealership or at least get an answer on cost.
But there isn't a security fuse I could just pull to lessen the annoyance?
Thanks for all the help...
Brad
Brad
Spartan66
11-20-2007 05:42 PM
