security issues
Old Oct 25, 2007 | 10:04 AM
100 footer's Avatar
Default security issues
is it possible to bypass the factory security system on my 95 v6, mine keeps kickin on like every other day, frankly im starting to get pissed. any help will do, thank you.
Old Oct 25, 2007 | 02:26 PM
Default RE: security issues
The PCM looks for a signal from the security module before allowing the starter to engage and the fuel injection to work. Can't bypass the security module without reprogramming the PCM, but you can bypass the pellet in the ignition key, or install a fake security module that sends a continuous signal to the PCM.
Old Oct 25, 2007 | 02:30 PM
100 footer's Avatar
how would i begin to do that
Old Oct 25, 2007 | 06:32 PM
camarorz28's Avatar
ORIGINAL: 100 footer
i would just buy a new ignition cylinder, it could be that one of your ignition wires i wearing down and the insulation of the wire has rubb into theignition cylinder housing. I know because mine started doing that until one day it just did not turn and mysecurity light flash, i took theignition cylinder offandone of thewires was broken.
Old Oct 26, 2007 | 07:56 AM
100 footer's Avatar
i took mine out and checked they seemed to be in tact and not broken on the insulation, but it could be on the inside cause even my remote start doesnt work sometimes, ill pobably just get a new one
chevydiva816
Aug 12, 2011 01:06 PM
jrgearhead
May 6, 2011 08:32 PM
serealport
Aug 20, 2009 08:17 PM
100 footer
Nov 1, 2007 01:01 PM
kyleb
Jun 15, 2006 01:37 AM
