rust in cylinder
Old Dec 26, 2007 | 04:15 PM
crgm101's Avatar
Default rust in cylinder
alright i have a .4 95 camaro it seized with water in 1 cylinder i got it broken lose and it turns fine. sould i refinish that cylinder or .... it seized because the spark plug was left out but i am rebuilding heads now and have all new gaskets so not a head problem. it is about the top inch that had the rust and it was thick flaky rust maybe 1/8 of a inch thick i scrubbed the exsess of with scotch brite and a razor blade.
Old Dec 26, 2007 | 08:12 PM
Default RE: rust in cylinder
Not recommended, but it may work out.
Old Dec 27, 2007 | 04:56 PM
Chappie99's Avatar
you can use the rabbit crap hone.
Old Dec 27, 2007 | 06:45 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
You will want to hone it clean... more importantly, how did enough water get in there to cause as much rust with only the spark plug left out? Little bity hole and alot of rust... just wondering.
Jeepin
Jun 27, 2011 02:12 PM
hgufrin
Jun 12, 2011 08:40 AM
tinytrucker
South
Apr 5, 2009 07:52 PM
hurley870
Dec 3, 2008 02:53 PM
mow_pro
May 8, 2007 05:47 AM
