revs with no accleration
Old Apr 25, 2015 | 07:23 PM
Blake_Camaro00's Avatar
Default revs with no accleration
While in gear going around 2000rpms I'll give the slightest touch to the gas pedal and it will jump to 4500-5000 rpm with no acceleration. I have to pedal the throttle to get the rpms to drop back down. Could this be the TPS or some other problem?
Old Apr 25, 2015 | 09:50 PM
torque_is_good's Avatar
manual transmission?????? clutch is slipping
automatic transmission- transmission is slipping
Old Apr 26, 2015 | 02:11 AM
It's a manual transmission and I thought the clutch might be slipping but it's not hard to put in gear and the clutch pedal isn't stiff
Old Apr 26, 2015 | 02:50 PM
Clutch slipping has little effect in selecting gears or pedal stiffness, if anything it makes things a little easier, but eventually the car is not going to move. Once the lining is worn off the clutch disk the metal parts of the disk are going to chew up the flywheel and cause it to get replaced or resurfaced. Get the clutch fixed before you get stuck in the middle of nowhere.
Old Apr 27, 2015 | 09:55 AM
and, since she'll be up in the air for this, it's a good time to replace the u-joints, the rear main seal of the engine, change the rear end fluid and replace pinion seal if leaking.
Old Apr 27, 2015 | 11:16 AM
Alright true true I don't know what I was thinking but I'm ordering the parts today, hopefully they will get here soon. Thanks for the tips and advice!
Old Apr 27, 2015 | 11:51 AM
if you have a two piece drive shaft have a look around for a one piece shaft from any 4th gen, its a direct replacement.
Old Apr 27, 2015 | 12:47 PM
just eyeball it to make sure there aren't a lot of dents and that the weight(s) didn't fall off. You don't want an unbalanced drive shaft unless of course you have some old fillings in the teeth that you are trying to shake loose. Once people are of the mindset that they no longer need the driveshaft or you find one in the boneyard, let's just say that they aren't treated gingerly.
Old Apr 29, 2015 | 08:24 PM
Lhh yeah Ik what you mean but I have a solid drive shaft already. Hopefully I can drop the tranny tommorow only a couple bell housing bolts left dont have much time Rn to work on it between work and school. Then I get to time my clutch and hopefully have it running by work on this weekend.
mpr21290
Mar 7, 2015 01:23 PM
RonnieJ86
Dec 5, 2012 08:58 AM
imcdowel
Nov 27, 2010 01:14 PM
vikingsfan211
82-92 V6 Tech
Oct 7, 2009 04:21 AM
mgray
82-92 V8 Tech
Jun 13, 2007 02:15 PM
