Reverse is gone?
Old 10-16-2008 | 09:47 PM
bryans3.4 95's Avatar
Default Reverse is gone?
i bought a 95 3.4l a couple weeks ago and it was doin fine until my bro loosened a bolt on the tranny. he thought it was the fill plug, trying to check the fluid, and it was the wrong one. he left it loose for some reason and i drove it a mile. its tight now and some wire next to it was taken out but is now in. i put it in the garage to have him change he rest of the fluids. when i tried o back it out, it wouldnt go into reverse the reverse lights didnt come on and i know it was going in i could feel it. its a five speed with a new clutch, it shifts through other gears fine. i did however accidently touch reverse, got a grind, while rolling back a little bit(4mph) and that might have caused it as well. there is a reverse lock but im not sure it does that or what it does really. if anyone knows the solution that isnt paying transmission guys $1000, please reply
Old 10-17-2008 | 01:01 AM
Default RE: Reverse is gone?
You onlyneed to post a question in one place. Here's my response again.
I do believe that he may have loosened the reverse shift lever pivot bolt...oops! And the wire by it would be to the reverse switch, for reverse lights. Might want to do a search online, or find a manual that shows exploded views of the innards of the trans.
Old 10-19-2008 | 10:51 PM
would you happen to know how to fix it? i searched google and got nothing.
skinut
04-11-2015 02:43 PM
boylemyster
09-05-2010 01:14 PM
bryans3.4 95
10-27-2008 01:40 AM
69dmz
67-69 V8 Tech
10-19-2008 10:26 PM
dorkpunch
06-29-2008 09:54 PM
