Replacing lower ball joints
Old Mar 2, 2006 | 11:58 AM
cop2700's Avatar
Default Replacing lower ball joints
I have a 1994 Camaro that needs one lower ball joint replaced. I really prefer to do it myself. I went and bought the part and the tool ( press from autozone), but when I got home, in my book, it says it needs to be replaced by a mechanic with a hydraulic press, any way around this and how would I do it?
Old Mar 5, 2006 | 10:22 PM
v8chvyguy's Avatar
Default RE: Replacing lower ball joints
Use the press , if you can, to remove the old joint. Otherwise knock it out with a hammer. Then spray a little penetrating oil on the new joint and press it in. Try to press it as straight as possible. I've done hundreds of ball joints and never had to use a hydrolic press.
adam86107
Mar 28, 2014 11:03 PM
chevcamaro
Feb 14, 2012 04:52 AM
Shalamara
Jan 10, 2012 11:01 PM
vjw757
Jun 24, 2011 11:43 PM
rdman
Jan 24, 2008 09:10 PM
