rear end trouble...again!!!
Old Nov 22, 2009 | 08:02 PM
heath3800's Avatar
Angry rear end trouble...again!!!
well a while back i had a problem with the rear end of my car making a whooshing noise. come to find out out i a very low axle fluid which caused my axle seal to break and my bearing to warp my rear left axel. so i had to buy a new axel. after i got the car back from the shop everything was great...until i drove over some train tracks and noticed a thump/grind noise coming from the side which has the new axle, i thought it was the shocks so i changed them out. the ride is a lot smoother but i can still hear the grind which sounds like its in the rotor area and i also noticed a small ticking noise that only stuck around for a few seconds. if anyone can help me out with some suggestions id appreciate it.
Old Nov 22, 2009 | 08:49 PM
have u checked the fluid level? could be in the brakes to how do they look? any oil on em? signs of heat?
Old Nov 23, 2009 | 09:46 AM
How many miles have you put on the car since the new axle? Did the shop warranty their work? You could take it back for them to give a listen to.
Old Nov 23, 2009 | 12:52 PM
libertyforall1776's Avatar
If all the bearings weren't replaced, you might have a bad bearing.
Old Nov 23, 2009 | 06:15 PM
heath3800's Avatar
everything seems fine with the brakes, i have 160,000 miles on the car and replaced the axle last month. both bearings and axle seals were replaced
Old Nov 23, 2009 | 08:35 PM
No, differential bearings.
Old Nov 23, 2009 | 08:41 PM
heath3800's Avatar
oh ok, i dont believe those were changed out. that would actually cause a clank noise at the rotors if i were to hit a rough patch of road?
Old Nov 23, 2009 | 10:55 PM
Are you sure it's at the rotors? Are you sure your wheels are snugged up?
If it's more of a whirring/grinding noise, it's most likely in the differential...
Old Nov 24, 2009 | 08:44 PM
heath3800's Avatar
yeah thats the exact noise its making... it kinda sounds like my wheel and brakes are gonna fall apart. i couldnt stand the sound no more so i took it back to the shop and wont hear anything til next tuesday. are differential bearing expensive?
Old Nov 25, 2009 | 01:42 PM
Really want to know? They billed my Ext. Warranty $840.97: $390.97 in parts (3 seals, 5 bearings, 1 spacer, 1 gasket, and 2 lubricant), $450 labor (4.5 hrs)
The bearings were pitted...
