Rear end oil?
Old Jan 11, 2015 | 04:20 PM
v64thgen's Avatar
Default Rear end oil?
Does the friction modifier additive for limited slip diff make the oil darker than normal?
Old Jan 11, 2015 | 05:01 PM
MKCoconuts's Avatar
Not that I've ever seen. Then again, I've always used the bottles that came with the additive in it already.
Old Jan 30, 2015 | 11:13 PM
J-Factor's Avatar
It shouldn't. Is this the limited slip or posi rear end? The gm additive is only needed if you have the posi. I asked the dealer about it recently since I'm going to be changing the diff oil soon.
Old Jan 31, 2015 | 10:01 AM
Only if the additive is noticeably darker than the oil, given the proportions of oil to additive. Why do you ask?
By the way, limited slip & Posi are the same thing. Limited slip is the function of the differential, Positraction is just GM's "proper name" for limited slip. Other car manufacturers have their own name they give to limited slip.
Old Feb 1, 2015 | 07:35 AM
v64thgen's Avatar
I only ask because I recently replaced my rear end with one from a junkyard, and I needed to install an actual gasket because the shop used sealant to make a gasket...and it leaked 😡. There was only a few thousand miles on the oil and it was pretty dark.
Saaampson74
Oct 20, 2008 04:56 PM
libertyforall1776
Nov 10, 2007 03:04 PM
