rear caliper
Old Aug 22, 2011 | 03:37 PM
silver97's Avatar
Default rear caliper
L.R. caliper is dragging even after replacing with a new one. Parking break is returning but the caliper isn't. Any ideas?
Old Aug 22, 2011 | 05:11 PM
slick's camaro's Avatar
have you tried bleeding them?
Old Aug 22, 2011 | 05:55 PM
silver97's Avatar
yep blead just fine, wondering if the rubber line is collpased internally
Old Aug 22, 2011 | 06:22 PM
blows my mind......but wouldn't you think if your getting fluid to the caliper, the lines are ok? how does the rotor look? possible it could be warped..
Old Aug 23, 2011 | 10:55 AM
ron316's Avatar
Default 97 camaro
more then likely the line is colapsing how much pressure do you get at the bleeder
Old Aug 23, 2011 | 04:12 PM
there are no specs for that but it should squirt out about 2-3 inches or so.
Old Aug 24, 2011 | 07:02 AM
ron316's Avatar
ya thats about right
Old Aug 24, 2011 | 11:12 AM
libertyforall1776's Avatar
You can always upgrade the flex lines with stainless steel braided lines, but also ensure the caliper slides move freely and are lubed properly. Plus check the pads that they are installed right and not unevenly worn, also ensure the rotor isn't warped...
Old Aug 24, 2011 | 04:32 PM
silver97's Avatar
It was the rubber hose, phew that makes me feel better till next project.
rs657f
Feb 15, 2025 12:02 PM
camaroteen82
Jan 3, 2014 04:10 PM
Yooper Z28
Aug 12, 2012 10:20 PM
4thknd95z28lt1
Mar 29, 2011 08:02 PM
350rs
Jun 1, 2009 05:26 PM
