random/multiple cylinder misfire?
Old Sep 25, 2008 | 12:42 PM
camarofreak1990's Avatar
Default random/multiple cylinder misfire?
ok i just took my 2000 3.8 v6 camaro to advance auto to get it checked bcuz its not running good at all. i can deff tell its lost power. when they hooked they computer to it, it said i had 2 bad 02 sensors, because my cat is gutted, and it said random/mulitple cylinder misfire, that code come up twice, and i just replaced the plugs like a week ago hoping that would fix the problem but it didnt, should i replace the pug wires next? or what should i do?
Old Sep 25, 2008 | 01:07 PM
MusicMan's Avatar
The Jazz Man
Default RE: random/multiple cylinder misfire?
How old are the wires? it's a possibility that it's coil related.
Old Sep 25, 2008 | 02:56 PM
Frechles71's Avatar
Look at the couple threads in the v6 tech area. There are two others recently with the same problem including one i started...
Old Sep 25, 2008 | 04:04 PM
02StanGT's Avatar
Which O2 sensors? Could be those are the cause of your misfire. I realize you said they bad because of no cat, but I would like to know for sure so we can rule them out.
walker61
Nov 29, 2014 11:01 AM
tonydavidson
Feb 23, 2011 12:32 PM
30thAnnivCamaro
Feb 23, 2009 06:43 PM
faces LT1
May 17, 2008 11:02 PM
briggette
Apr 21, 2006 02:20 AM
