radio and windows shorting out
i have a 97 camaro i just got the other day and every once in a while about every other time i drive during the drive the radio and windows stop working then start again later ive heard there is possibly something in the door that can do that but really have no idea has anyone else seen this problemand found a way to fix it......................extra q where are the wiring harness for this they both shut off at the same time
Check your wiring harness connections going to them to make sure they are plugged in good. Might be a loose connection or damaged wiring. There is a rubber boot looking thing that you will see at the front of the door the wires are running through.
Camaronoob
01-27-2008 11:03 AM
