question can a 94 v6 be switched for a 98 v6
Old Jan 23, 2009 | 04:26 PM
joeyh2005's Avatar
Default question can a 94 v6 be switched for a 98 v6
98 v6 is the application the same as a 94 v6
Old Jan 23, 2009 | 05:13 PM
02StanGT's Avatar
It's not the same engine. It will fit, but will require alot more than just the engine.
Old Jan 23, 2009 | 10:20 PM
Didn't we just have this conversation last week? Search function must be broke again.
https://camaroforums.com/forum/93-02-v6-tech-14/3-4-3-8-a-1507/
Old Jan 24, 2009 | 02:50 PM
bluovlh8er's Avatar
dont waist your time go for the LT1 swap!
Old Jan 25, 2009 | 04:06 PM
RS96LSU's Avatar
screw the lt1. go for the ls1
Old Jan 25, 2009 | 06:51 PM
spacemule's Avatar
Switching engines on anything is rather asinine. If you want a car with a 3800, buy a car with a 3800. If you want a car with an ls1, buy a car with an ls1.
Thing is, by the time you get through jacking around with everything that will need to be changed, you'll already have as much in the thing as it would have taken to get what you wanted in the first place. Not only will you have too much money in it, the car will be worth less because you've monkeyed around with it. I mean really fella, you want to change one v6 for another? Jimminy crickets and rectal cranial transpositions and spank me with a stick!
Old Jan 25, 2009 | 08:12 PM
MusicMan's Avatar
The Jazz Man
I don't know what the heck you just said, but it's funny.
Old Jan 25, 2009 | 09:27 PM
spacemule's Avatar
That makes two of us.
Old Jan 25, 2009 | 09:35 PM
camaro_burns_all's Avatar
VIP member
a switch from lt1 to ls1 can be done but requires much work. Better off just finding another lt1 engine
Old Jan 26, 2009 | 12:32 PM
bluovlh8er's Avatar
dumbass the whole reason they put the new front end on 98-02 was cause the ls1 would not fit right in the 93-97 front. he would have to switch the whole front end too. too much $$$ just buy an ls1 car.
BLK79
Jun 3, 2014 08:40 AM
JPrice
May 20, 2012 03:48 PM
schulzmc
Aug 14, 2011 03:24 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
