pushrod knock
Old Aug 22, 2008 | 09:14 PM
92lxsleeper's Avatar
Default pushrod knock
i think i have pushrod knock. how much would it cost to fix it? 1993 camaro 3.4L V6
would it be more cost efficient to drop a 3.8L into it?
Old Aug 23, 2008 | 11:52 AM
importmd's Avatar
Default RE: pushrod knock
it could berod knock(connecting rod) meaning spun bearing, piston slap, lifter tick, no such thing as pushrod knock. pushrod is a rod that sits on alifter that rides on the cam, and goes up to the rocker arm to open and close the valves. they dont make noise.
Old Aug 25, 2008 | 11:25 AM
greg w's Avatar
heavier oil for right now. From what I understand and have taken from other posters, is the 3.8 is a real mother to work on in these cars. If I where considering engine replacement I would go with stock or upgrade all the way to a v-8
Old Aug 25, 2008 | 04:40 PM
Where is the noise from, the heads or down inside the block?
Old Aug 25, 2008 | 08:16 PM
magnum041's Avatar
do tou have a drop or rise in oil pressure if so most likly a spun bearing
Old Aug 25, 2008 | 08:18 PM
magnum041's Avatar
also you can cut open your oil filter with a chisel and cut out about inch of filter wrap in arag and squese in a vise gently and open to see if it full of metalif so teardown would be nesc
Old Aug 25, 2008 | 10:30 PM
Bowtie Or No Tie's Avatar
drop the oil pan....
see if there isany metalshavings on the magnet... (black square inside the oil pan)
if there is;you prolly spun a rod bearing.
Old Aug 26, 2008 | 10:40 AM
ORIGINAL: magnum041
my oil pressure gauge is broken. i think it is a spun bearing
RamzaFreak20
Oct 17, 2011 01:02 PM
3.4_V6_Maroboy
Sep 20, 2009 09:42 PM
jxdesign
Feb 11, 2007 03:13 PM
hotrodguy1986
Nov 13, 2006 02:12 AM
gotalcoholmanup
Jun 28, 2006 02:29 AM
