PROBLEM!!!
Old Sep 2, 2007 | 09:29 AM
TotalChaos's Avatar
Default PROBLEM!!!
OK i have a 1997 RS Camaro and it seems to have something clogged either a fuel filter or a injector. The thing is we just had it serviced not too long ago maybe 9 months.... It seems to idle ok but when i put it into gear it acts like it is going to die. As long as i don't accelerate too fast it seems ok but say i want to go from 35 to 45 i have to do that very slowly or it will sputter. So my question is has anyone else had this problem and if so your input would be greatly appreciated.
Old Sep 2, 2007 | 11:29 AM
Default RE: PROBLEM!!!
Id the MIL lite lit or flashing? If it is get the car scanned. If it isn't misfiring, then check the TPS.
Old Sep 2, 2007 | 11:40 AM
TotalChaos's Avatar
no there are no warning lights on.... today i went to drive it and everything seemed fine. so apparently overnight something happened.
Old Sep 2, 2007 | 12:24 PM
JaySan's Avatar
check ur ignition coils. You may have a bad coil. Like I had that problem. When I would accel. fast it would sputter. But If i press the gas FIRMLY i would get up to the speed I wanted to go.
Old Sep 2, 2007 | 07:35 PM
TotalChaos's Avatar
ok thanks i'll check into that asap
Old Sep 2, 2007 | 07:59 PM
Chappie99's Avatar
Under a load it gets poor excelleration? Possibly plugged C.A.T.
Old Sep 3, 2007 | 10:12 AM
bluovlh8er's Avatar
i had 2 injectors go on me and it did the same thing
Old Sep 3, 2007 | 12:03 PM
TotalChaos's Avatar
the only reason i don't want to think it is the injectors is because we just had it tuned up and all of that was cleaned and checked.
Old Sep 26, 2007 | 12:09 PM
100 footer's Avatar
my girlfriends camaro is doing that now, we changed the egr valve o2 sensors and we had the injectors cleaned and a new feul filter still no go, were changing the cat this weekend, but if you figure it out let me know what it was please
Old Sep 26, 2007 | 01:12 PM
facingxtinction's Avatar
had that problem a year ago... It was the CAT. A fuel injector would set off your Check engine light, and possibly have it blink on and off. Check the CAT as soon as you can, cause driving it too long like that will ruin your transmission.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
