Prestone Flush Kit Install Guide 3.8L Camaro
For a Prestone Flush Kit Install on the 3800 Camaro, the arrow on the metal at the spire pointing into engine is the heater inlet (i.e. bottom one) which is where the tee is supposed to be installed, correct?
Now if the tee is installed on the other hose (outlet), the difference is you just don’t get a good heater core flush, correct?
Clearly Prestone's guidance SUCKS! “Hose #2 runs from fire wall to top of engine.* This is the heater inlet hose.”
| Prestone®
| Prestone®
libertyforall1776
LS Series Tech
Apr 29, 2014 10:16 PM
libertyforall1776
Oct 18, 2010 01:50 PM
