Poppin noise WTF
Old Jan 15, 2008 | 04:29 PM
3.4CamaroCDOG's Avatar
Default Poppin noise WTF
enough is enough im tired of this poppin noise i changed the spark plugs the oil and filter and i checked for intake leaks and there are none. But im still gettin this poppin noise i cant even get my car scanned at autozone or any auto place because they only scan 96 and up but wtf the 95 camaro 3.4 and 96 camaro are the same arent they? can someone give me a list of wat my problem could be? it is also revving real high at first start and in nuetral. do u want me to make a vid cause i can try?
Old Jan 15, 2008 | 04:41 PM
02StanGT's Avatar
Default RE: Poppin noise WTF
'96 started the 3.8 era. No more 3.4. Also '96 started the OBD-II. '95 is OBD-I. Nothing is the same.
Old Jan 15, 2008 | 05:17 PM
Chappie99's Avatar
explain the "poping" noise. From the exhaust tail pipes like a back fire?
Old Jan 15, 2008 | 05:20 PM
naw its from under the engine like on the driver side its annoying and draining my power when ever i step on it
Old Jan 15, 2008 | 05:21 PM
*hood
Old Jan 15, 2008 | 11:14 PM
Chappie99's Avatar
sounds like a exhaust leak. Check your manifold to y-pipe connection. Possibly cracked exhaust manifold.
Old Jan 16, 2008 | 12:39 AM
02StanGT's Avatar
ORIGINAL: Chappie99
Word. Though in previous posts you said it sounds like misfiring. Also you said a couple spark plugs were white, which indicates a lean condition. Hence, as I answered in the other post, perhaps you have a few injectors that need cleaning...
Old Jan 16, 2008 | 11:29 AM
an exhuast leak could cause a misfire noise?
Old Jan 16, 2008 | 11:33 AM
02StanGT's Avatar
Exhaust leaks sound like ticking. Can make your car sound like poo.
Old Jan 16, 2008 | 11:38 AM
yea its ticking but it also is poppin or misfiring when i step on the gas real hard
