Please is there a camaro god out there !!
please help!!! (3.4L 1995)
I have been having some problems since last summer.... first my car was like going into convoltions. It would shiver but it only happend in the winter. but since that when the warmer weather has come it stopped. Now the cars RPMs go rev..rev.... when i go through turns like when im getting off the highway... another problem im having is the interior light stays on when i shut the car door so i found the problem i think... then wire that connects to the door panel was not connected so i wrapped it with electrical tape lol its hard to find thos plaatic bumper pcs to the dome light sensor... the security light started coming on !! FML! and the car would take like 3 mins for it to shut off !!! then it would be fine until i shut it off again. then i would have to go through the waiting problem again.... now since that has happend the #5 PCM IGN fuse keeps popping when I turn it over.... but if i wait like an hour itll be fine... then that happens again!!! Pain in the @ss !!!!! now I did have some over heating issues as well i replaced the radiator and upper and lower hoses... got all the air out and the car hasnt over heated since !!!
can someone please help me!!!!
Last edited by CanDi apPle Camizzi; 07-23-2010 at 04:19 PM. Reason: wondering y my signature isnt working?
how are you checking. if its not throwing codes then i would check all the grounds and clean em if they need it. theres also a power junction box on the passenger side fenderwell (red plastic box) clean them with a wire brush. check and clean the ground junction there as well. you should have a ground strap on the driver side at the front of the motor. should be ground wires on the block by the starter and at the front on the passenger side. check the fuse boxes for any heat or other damage, look over the wireing as best you can. it would be a good investment for you to pick up a factory service manual for your yr and model. this is what they look like so you can look for a better deal. you may find one on cd for less as well.
http://cgi.ebay.com/ebaymotors/1995-...ht_1951wt_1167
Your revving problem could be the IAC motor. How does the car idle? Get some throttle body cleaner and clean out the intake on the car along with the IAC motor. When's the last time you changed your PCV valve? If it's clogged it'll cause that issue as well. As for the security light, it is electrical. It could be the wiring behind the glove box or the anti-theft cylinder that's failing. Do you have another key for the camaro? If so try it and see if you get the same problem.
Could the security light be popping the PCM iGn fuse? I figure out the other problem my uncle put a standard PCM in my car when I have a auto. It runs fine but now the fuse is poppin still. Only when I have been driving it for a while. Then when the car chills out I can start it with out the fuse popping. But the security light still keeps coming on.
