P0336? PLEASE HELP!
Old May 27, 2007 | 09:36 AM
adams96camaro's Avatar
Default P0336? PLEASE HELP!
"crankshaft position sensor a circuit range/performance"
Keep on getting this code on my 96 camaro 3.8 auto, rally sport! Can anybody help? Should I replace the whole sensor, or is there something else I should look at? Thanks
Also does anybody have a digram or know where I would find the crankshaft sensor?
Old May 27, 2007 | 10:58 AM
Default RE: P0336? PLEASE HELP!
Change the sensor before the car stops running.
Make sure the electrical connectors are clean and tight.
Under hood, center, front engine area, rear of crankshaft pulley, mounted in engine block.
Replacement:
Look for 3.8 section,
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old May 27, 2007 | 12:37 PM
libertyforall1776's Avatar
I think that indicates a timing issue -- right?
Old May 27, 2007 | 02:13 PM
All position sensors are related to timing.
Old May 27, 2007 | 08:19 PM
usarmyrangrs's Avatar
Also make sure the reluctor ring is clean and not damaged.
Old May 28, 2007 | 01:27 PM
Great thanks for the help, I will buy a sensor tommorow and check everything and I will get back to you guys...
Thanks again
Luke Whitley
Feb 9, 2015 07:18 PM
98camarov6
Jul 3, 2012 08:58 PM
klimtog
Jul 4, 2011 01:53 AM
