over heating problem?
Old 08-11-2009, 11:23 PM
jproud27's Avatar
Default over heating problem?
I noticed that my 1997 3.8L camaro was running hotter the usual the other day so i took it home and checked my coolant levels. They were a little low so i added more coolant. The next day on my way to work it was a little bit better but was still running hotter than it normally does. I stopped and had my car in park, still running and in the matter of a couple minutes the temp rose almost to the red. i figured it was my thremostat so i replaced that and i flushed the cooling system. When i was driving it after i replaced the thermostat and flushed the cooling system to see what the temp would do it was right around 180 but when i got home and let it sit it jumped up to almost the red again. anyone have any ideas on what might be wrong?
Old 08-12-2009, 12:00 AM
are the fans working?
Old 08-12-2009, 12:01 AM
jproud27's Avatar
Yea i can hear them turn on when it gets really hot.
Old 08-12-2009, 12:19 AM
fan should come on before it get really hot. clean or change the temp sensor should be in the head, front driver side i think. not the temp gage sensor should be in the intake manifold. is it running ok?
Old 08-12-2009, 08:21 AM
jproud27's Avatar
It runs allright I guess I need to change the plugs and wires and it has a slight knock when it idles but it has done that for the past 2 years/50000 miles
Old 08-12-2009, 09:03 AM
94ttop's Avatar
any leaks
Old 08-12-2009, 01:39 PM
jproud27's Avatar
no there aren't any leaks but while i was driving it today it was still getting hot but on my way home i turned on the A/C for a couple minutes and the temp started to go down. once i got home i let it sit for awhile with the A/C off to see if it would get hot again and it did but it took alot longer today than it did yesterday to get really hot?
Old 08-12-2009, 06:07 PM
FormulaRS's Avatar
I had an "overheating" issue today too. I was in stop and go traffic and it never rose above the 1/2 way notch, but the car usually operates at the first notch on the gauge. I couldn't hear the fan, but I'm not sure what it would sound like anyways.
Old 08-12-2009, 06:14 PM
im thinkin your fans are not coming on. could be the temp sensor or the fan relay. relay is in the elecrical box under the hood., black box. not sure if u have two fans but if u do there will be two relays.
Old 08-12-2009, 07:30 PM
02StanGT's Avatar
i'm with craby on the fans not working with the a/c off. the fans will kick on when you turn the a/c on which is why it's cooling back down.
Quick Reply: over heating problem?
