Oil sending Unit
Old Nov 12, 2009 | 07:14 PM
JordanN's Avatar
Default Oil sending Unit
Where is the oil sending unit located on the v6?
( Tried searching, sites going really slow )
Jordan
Old Nov 12, 2009 | 07:22 PM
x01660's Avatar
The Mustang Hunter
Hope this helps
x01660
File Type: zip
Old Nov 12, 2009 | 07:28 PM
osduck5's Avatar
If it is a 3.8 liter, it is just above the oil filter and is about 2 inchs long round piece that is screwed into the block.
Old Nov 12, 2009 | 09:12 PM
nnewquist's Avatar
The profile says he's got a '95, which would be the 3.4L.
I'm not 100% sure, but I think on that engine it's located near the back on the driver side. It can't be too hard to locate, though. As osduck described, it's a 2- or 3-inch round piece screwed into the engine. It sticks out like a sore thumb, quite literally. Easiest thing in the world to replace, but BE CAREFUL. I know of several people who've broken them when trying to install the new ones, LOL. They're fairly fragile parts.
Old Nov 12, 2009 | 11:00 PM
Jonny Dubyah's Avatar
yea i sneezed wrong at mine when changing my oil and it broke..it will probably be mostly black plastic with a silver metal base with a wire plugged to the end of it..
Old Nov 13, 2009 | 07:56 AM
nnewquist's Avatar
Yeah, most things in these cars are really well designed and built to last, but this part and the hard-to-reach spark plugs are just stupid ideas. WTF was GM thinking?
At least this thing is cheap and easy to replace.
Old Nov 27, 2009 | 01:06 PM
tray z-28's Avatar
on the 3.4l the oil pressure sending unit is located on the driver side down the bottom back end of the motor, wen i got my 95 mine was already snapped off. you may have trouble finding it if i remember correctly its got a rubber hose over it but its back there. if u havnt already found it i hope this post helps.
royco95
Jul 16, 2011 10:20 PM
jjz28
Mar 11, 2010 04:04 AM
M.$tErNeR
May 1, 2008 10:55 PM
maxxiepad
Jun 16, 2007 08:32 PM
ohiocopper12
May 10, 2007 10:09 PM
